Before I buy????
marty4sh
Before I buy????
Post by marty4sh »
Hi can anyone confirm that if I purchase the software I can use my VAGCOM Dual-K & CAN interface will reset the DPF on a 1.3 doblo multijet deisel? Thanks.
Juggers2k
Re: Before I buy????
Post by Juggers2k »
I don't believe the K+Can interfaces will work with FES.
What chassis type is your Doblo, as that affects which interfaces it will work with.
marty4sh
Post by marty4sh »
Juggers2k wrote:I don't believe the K+Can interfaces will work with FES.
Hi, should have explained this is my mothers car so don't have the details to hand, it is the car version 2007 reg and has the 1.3 multijet diesel engine. The cable I have has the following info...VAG-COM CAN BUS Super 812.4 Dual-K & CAN <-> USB VAG/ISO interface.
I thought I read on the main page that VAGCOM cables were compatible with this program?
marty4sh
Post by marty4sh »
Ok then...... Was going to buy but without the info I am not going to spend 40 odd euros on the off chance. Booked in at the Fiat dealership tomorrow to have the reset done instead. Missed out on a sale there ;)
Juggers2k
Post by Juggers2k »
marty4sh wrote: Hi, should have explained this is my mothers car so don't have the details to hand, it is the car version 2007 reg and has the 1.3 multijet diesel engine. The cable I have has the following info...VAG-COM CAN BUS Super 812.4 Dual-K & CAN <-> USB VAG/ISO interface.
VAGCOM KKL cables are compatible, but K+CAN cables aren't.
Crucially they are only compatible with some vehicles though - for others (including the recent Doblos) you need to use a CAN enabled interface - either the ELM327 or the OBDKey.
