Changing Kms in Dashboard Fiat Stilo
ove1kenove
Post by ove1kenove »
Hello, my Fiat Stilo has 90000km and i have installed an Abarth dashboard on it. The problem is that the dashboard display 200.000kms. is it posible to change and fix to the 90.000 kms of the car? thanks.
Re: Changing Kms in Dashboard Fiat Stilo
Multiecuscan is NOT able to reduce dashboard odometer values. It can only increase them. Also trying to increase the value to 999999 hoping it will wrap to zero an then setting new value of (in your case 90,000km) will not work either.
I gather there are tools available out there that claim to be able to reduce odometer values. I've no idea if they work or not.
Aron96
Post by Aron96 »
s130 wrote:Multiecuscan is NOT able to reduce dashboard odometer values. It can only increase them. Also trying to increase the value to 999999 hoping it will wrap to zero an then setting new value of (in your case 90,000km) will not work either.
Hello s130, I find myself well with the same situation ove1kenove you do not know what other program is through the EOBD this work, I ask if anyone knows any other program that does this job the car and year 2004
fiat stilo 115hp
regards Aaron
