AR156 2.4 JTD
darkoman
AR156 2.4 JTD
Post by darkoman »
Alfa Romeo 156 2.4L 2001my Engine wont start. No DTC's, rail pressure OK, Engine rev OK but no start.. :(
Any help is welcome!
B. R.
Darko
Re: AR156 2.4 JTD
Try to check connectors on relays... Open the hood and close to battery should be some relays!
Just unplug them and plug them back! You can do it one by one!
If you have some kind spray which can clean the connectors, just spray on the contacts - relay board...
darkoman
Re: AR156 2.4 JTD
Post by darkoman »
alfa156sarajevo wrote:Try to check connectors on relays... Open the hood and close to battery should be some relays!
thanks for help, but still no joy.. :(
Aron96
Re: AR156 2.4 JTD
Post by Aron96 »
try to disconnect the tube that is connected to the intake and throw a bit of choke, and starts putting the hose if a part of this occasion, the car can go from one center to show pompista Bosch injectors :D
Re: AR156 2.4 JTD
Maybe it is a Crankshaft position sensor (CKP) OR camshaft position sensor (CMP)! :roll:
But I think it is the first one! When JTD engine won’t start usually it is CKP sensor... :roll: :roll:
alfadave11
Re: AR156 2.4 JTD
Post by alfadave11 »
crank sensor with out doubt
darkoman
Re: AR156 2.4 JTD
Post by darkoman »
Solved!
All 5 injectors was blocked becose of bad fuel...
B.R.
Darko
