Fiat Bravo II 1.6 MJET 120hp AIRBAG not connecting
I'm having problems connecting to the Bravo 1.6 MJET 120hp airbag ecu, it does not find it. Actually the only ecu that will go into diag. is the engine (EDC16C39) all others will not communicate. I am using a ELM327 1.4 interface. Any ideas?
Re: Fiat Bravo II 1.6 MJET 120hp AIRBAG not connecting
Never mind I found the problem. I removed the 120ohm CAN resistor in the ELM interface and not it works perfectly.
