I have a registered version of Multiecuscan on my laptop. But I'm having problems and need to re-load windows. (Nothing to do with Multiecuscan). If I re-load windows will I get the same hardware key and so able to use the same License Key aftewards. Or would it be better to transfer the Licence to another computer and then transfer it back once I have re-loaded windows. (I am running Windows XP). Obviously I don't want to risk loosing my licence.
Thanks in advance for your help.
Claudio
Re-loading Windows On My Laptop
Re: Re-loading Windows On My Laptop
The Hardware Key should not change after the re-install.
But, if it happens for some reason just send me an email and I will fix the problem...
Thank you for your reply. Should I get a deactivation code, just in case, or will that cause problems when I put in the activation code again.
Thank you in advance
Claudio
Claudio
