service reset bravo 2008 1.9jtd
wilco1v
Post by wilco1v »
service reset not goingwel with fes
red oil lamp blinking (text in display ..something like ...change oil...???)
service reset @ the dealer they reset service in engine ecu and than service reset in the instrument
did i mis something in fes ???
greets wilco1v
Re: service reset bravo 2008 1.9jtd
That is normal.
With the newer diesel engines in addition to the regular Service Reset function which resets the counter in the instrument cluster you have to connect to the engine module and execute the 'Oil Change' procedure. You can do it with Multiecuscan if your engine is supported.
wilco1v
Post by wilco1v »
thanx yani
fes did not point a message to do olso service reset in engine ecu module and dash
next time i now better
greets wilco1v
next time first ask here and then if nobody is responding go to dealer... ;)
