What can be done with the grande punto with this software then?
Can you activate any functions such as auto lights when the car is unlocked or auto closure windows when the car is locked? How about the alarm beeping when the car is locked? I know with the new canbus VAG vehicles you can activate so that when you turn the ignition the speedo and rev counter do a needle test and go right round to max speed/rpm then back to 0, would this be possible?
Also would it be possible to be able to tell the car to stop monitoring the EGR valve on my MJET? Or even disable it?
Any help would be appreciated.
Thanks,
Ben
Grande punto
Re: Grande punto
I would like to know this as well
Re: Grande punto
No, no, no and again no
You can do diagnosis, change some values, service reset, proxy alignment (new dashboard..cruise control...and so on), buzz of...
you can make use of features that are already supported... you can't make new ones.
