Hi all
as title suggests, my new laptop, which has Windows 7 Home Premium 64bit OS, won't support my cable, so FES is currently unavailable for me!!!
Can anyone point me in the right direction for the correct cable and/or driver i need to get up and running again please?
cheers
Cable wont work with New Laptop on 64bit Win 7, Please Help?
Re: Cable wont work with New Laptop on 64bit Win 7, Please H
What cable are you using?
A lot of the ELM and KKL cables use a USB serial convertor based on the FTDI VCP chips.
You can get drivers for those from here:
http://www.ftdichip.com/Drivers/CDM/CDM20814_Setup.exe
That exe file will do the job and sort it out also used that one on my VAG OBD2/USB via win7/64
also check out this page for more info on the correct drivers
http://www.ftdichip.com/Drivers/D2XX.htm
