Hello, Im new to this forum and i want to use this opportunity to say that you have develop good software.
I have small problem with my car only all other car are ok with this software. Car is punto 2000. 1.2 8v
Cable is kkl 409.1 usb all parameters are correct. tested on few diferent cars and working: alfa 147 SELESPEED, puntos: HGT, SPORTING JTD, SPORTING 16v.
FES was 3.2 and 2.5! all showing me same as you can see on picture i have provide.
Other optiones are working i can monitor parameters, graph, errors ( but i did not have them) acutator.
Not shore but i thing adjustments didnot working...
error iso code is:
ENGINE UNKNOWN/UNSUPPORTED
0D 07 0D 98 0E
Now what i should knew and expect about this.
Greatings Edin.
INVALID ISO CODE 1.2 8v punto BUT!!!
Re: INVALID ISO CODE 1.2 8v punto BUT!!!
i would check the ecu version of your car and then search for it in FES.
Open the hood/bonnet of your car; the ecu should be behind and under the air box, or on the left of the battery...or i don't know
Maybe the ecu version is different from the one listed under "Punto '99" but still supported under other cars (punto '03...panda...)
