Hi Yani,
I activated the display of parking sensors, but I noticed that the operation is not correct.
The system detects obstacles that do not exist and, when used, the sensitivity is not correct.
The problem can be caused by incorrect calibration between the unit and the body computer?
The problem is common to many others who have performed the procedure.
You may kindly see if the problem can be solved?
Thanks, Andrew
