My car is a Fiat Brava 1.6L 1.6V R reg with Marelli IAW 1AF with Engine number 182A4.000. Will there be an update that allows to communicate with it? It takes 3ways connector (Not OBD2).
Regards
Edmund
P.s.
Found this list which show ECU, Year, engine numbers and Model of Fiats.
http://www.sun-diagnostics.com/products ... Fiat3x.htm
IAW 1AF
Re: IAW 1AF
Hello, I also have a Fiat Bravo 1.6 (1996) with the same pre-OBD ECU (Marelli IAW 1AF 13/15 ....). I wonder if there will be an update for this model of ECU in the next version of multiecuscan (is it technically possible?) Anyway, congratulations for this program that seems to work perfectly! Thank you
