i have a 147 in my workshop that i have replaced the engine for a second hand unit all old stuff put back on so only the block and cylinder head has been changed,
The basic problem is rough idling almost like a pulsing, after a bit of info i am told it cold be the lambda sensors a couple of times it has come up with different errors but i feel it is due to whatever is the matter, i have actuated all the components listed in the fiat ecu scan and all seem to actuate except for the lambda sensor replay ( i cant hear it clicking in at all on either of the actuators.
But the biggest problem is i cant find the lambda sensor relay? i have looked at Autodata and tolerance (tolerance making the most sense of the fuse box layouts )
but i still cant find the relay in question PLEASE PLEASE HELP!!
phil
