Alfa Romeo 159 2.2JTS 2005year
amiko
Post by amiko »
Hi all!
Thank you for creating such a useful thing for Italian car lovers :)
I have read many topics about multiecuscan, BUT I wanted to open this topic anyway, just to comunicate with you and be sure not to make any mistake while choosing correct software/hardware for my car.
MY FIRST QUESTION IS:
1. What exactly should I buy (I mean USB connector cables etc.) to make it work with my Alfa Romeo 159 2.2JTS 2005year? (ECU, Airbag, and averything)
ARomeo
Re: Alfa Romeo 159 2.2JTS 2005year
Post by ARomeo »
amiko wrote:Hi all!
Depends on your computer. If it has serial port - best way. If not - USB
amiko
Post by amiko »
Why serial port is better then USB?
amiko
Post by amiko »
NO ANSWER?
amiko
Post by amiko »
I have disabled light washers operation from "CAN Setup / PROXI AlignmentProcedure" and now I can not enable it back...
I just can not find it in the list any more...
Can anyone help me?
I have got 159 2.2 JTS 2005 year
It is there in "CAN Setup / PROXI Alignment", in Adjustments
In English it is called "Headlight washers"
amiko
Post by amiko »
yani wrote:It is there in "CAN Setup / PROXI Alignment", in Adjustments
Yes, I know that. I found it exactly in "CAN Setup / PROXI Alignment" and disabled it.
After 2-3 days, I tried to enable it back, but could not find it in "CAN Setup / PROXI Alignment" menu.
The same thing happened with "seat belt warning tone" item.
Could I delete them forever?
amiko
Post by amiko »
Where can I find "seat belt warning tone" item in the menu?
Juggers2k
Post by Juggers2k »
amiko wrote:Where can I find "seat belt warning tone" item in the menu?
On most models you need to connect to the instrument cluster (from memory!), then look at the adjustments tab.
