Fiat Stilo 1,6
Marek Sp
Fiat Stilo 1,6
Post by Marek Sp »
I have a problem with this car, 15 minutes after the engine is not working and I can not connect to it. Then after some time everything is OK and the engine is running normally, I can connect but I have a fault code, the wrong signal to the immobilizer. Coil? and what else could it be?.if you manage to start the engine are the codes U1702, U1600, U1700, U1706 After removing remains constant codes whose code 1702 can not remove .Please, all suggestions
