Fiat/ Lancia/ Alfa Romeo - Error codes with no description
Hi Yani,
I have few questions regarding description of error “05”.
I have been working on Lancia Kappa 2.0, made in 1997.
Each time when I connect with FES I got the error called “05” but it has no destripcion.
Here is report:
ECU ISO Code: A8 86 13 13 29
CONNECTED TO:
LANCIA K 2.0
Bosch Motronic M2.10.3 Injection (2.0, 2.4 20V)
ECU ISO code: A8 86 13 13 29
Software version: 0835537301
Hardware version: 0763021620
FIAT drawing number: 0265364640
READING ERROR CODES:
1: 05
The reason for this fault is Unknown
The current status of the fault is Intermittent / Present
The error counter value is 10
So Yani can you tell me what this error 05 means?
Thanks,
Here is report:
CONNECTED TO:
LANCIA K 2.0
1: 05
Thanks,
Re: Lancia Kappa 2.0 - Error 05 - no description
Error code 05 is "RPM sensor" in M2.10.4. I can't find error code 05 for M2.10.3.
Anyway, can you send me a report after reding this error to be sure that it is not some kind of bug.
Many thanks Yani!
Re: Fiat/ Lancia/ Alfa Romeo - Error codes with no descripti
Hi Yani,
It is me with new questions...
I even changed the name of the topic so we do not need open new topics for some error codes that don't have description.
I have few questions regarding description of error “P1684”.
I have been working on Fiat Stilo 1.6 16V, made in 2001.
Each time when I connect with FES I got the error called “P1684” but it has no description.
Here is report:
ECU ISO Code: 0D 07 98 01 02
CONNECTED TO:
FIAT STILO 1.6 16V
Magneti Marelli IAW 5NF EOBD Injection
ECU ISO code: 0D 07 98 01 02
FIAT drawing number: 55187475
Hardware number: IAW5NFHW102
Hardware version: 00
Software number: 2616K31B
Software version: 0000
Homologation number: 5NFT1
ECU programming date: 01/21/2008
1: P1684
The reason for this fault is that ECU has received invalid signal from the sensor. The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was activated for this fault.
CLEARING ERROR CODES...
No fault codes
So Yani can you tell me what this error “P1684” means?
Thanks,
Here is report:
CONNECTED TO:
FIAT STILO 1.6 16V
1: P1684
No fault codes
Thanks,
Hello I really just wanted time to send an error code table, but your mail is blocked
http://www.club-fiat.com/viewtopic.php?f=9&t=12249
P1684
Metering Oil Pump Position Sensor Circuit Malfunction
greeting
wombi
Turkey
P1684
greeting
wombi
Turkey
Thanks wombiwombi wrote:Hello I really just wanted time to send an error code table, but your mail is blocked
P1684
greeting
wombi
Turkey
But the problem is that on another FIAT fault codes list I found this:
P1684 Motorised throttle (plausibility)
So right now I have no idea what this fault code mean...
I will wait for Yanis respond...
And I have no Idea what to think
Error P1684 on this engine means "Throttle position learning".
Hi Yani,
I have questions regarding description of error “47”, open circuit.
Marea 1.8, made in 2000.
So, the car is Marea 1.8 with pre-98 HITACHI ECU.Espi wrote:Hi Yani,
I just checked the Hitachi documentation. Error 47 means "Lambda sensor short circuit to Ground".
Thanks Yani!yani wrote:Error P1684 on this engine means "Throttle position learning".
