FES 2.8.2 reports in the Engine ECU Parameters that ABS is not present where as cruise control is. Is this a bug ?
My car is a Fiat Stilo 1.6 without cruise control
A picture of the parameters can be found at the following web page
http://www.fiatforum.com/gallery/upload ... METERS.GIF
FES 2.8.2 wrongly reporting Cruise control present
Re: FES 2.8.2 wrongly reporting Cruise control present
If you correctly connect cruise control device, you can use CC. This funcionallity is available in your car, but there is no steering device. Just connect it and ... works fine.
This is actually a bug. The 3 parameters (Cruise control present, ABS present and EPS present) were showing wrong values. Will be fixed in next version.
Thanks for reporting this.
Hi Yani, I had another few problems whilst trying to connect to the ABS ECU. I could not connect to the ABS ECU with the adapter cable and my Elm 327 Blue tooth adapter, I just kept getting a message saying operation Timed Out. The adapter is a genuine adapter with version 1.3 firmware and it works correctly with the Engine ECU, service reset and CAN Bus information.
I did manage to connect to the ABS ECU using the VAGCOM adapter however Latency Too High kept being displayed in the status bar and the connection was very unreliable. When I checked the Latency setting for the Comport it was set to the minimum value - 1.
Do you have any suggestions as to what is causing these problems?
Kind Regards,
Philip
Kind Regards,
Philip
