punto evo 1.4 8v
nightjedi
punto evo 1.4 8v
Post by nightjedi »
i try to connect Fiat Ecuscan to my PUNTO EVO 1.4 8v and i have problems
TEST OK
but can´t conect to mudules, only works Steering
results of my scan
MOTOR
UNKNOW / UNSUPPORTED
ISO Code: 0D 07 76 08 67
ABS
UNKNOW / UNSUPORTED
ISO Code: EC 07 08 07 57
DIRECCION ELECTRONICA
Delphi electric Steering (2)
ISO Code: 31 83 13 08 A4
COMPLETADO
FESLog_1105091812_FIAT PUNTO EVO 1.4 8V.txt
LOG PUNTO EVO 1.4 8V
(426 Bytes) Downloaded 119 times
sixpotman
Re: punto evo 1.4 8v
Post by sixpotman »
Are you using adapter 3 or a cable
altered to match the pin connections used
by adapter 3?
John
Your engine ECU is "Marelli IAW 5SF3 CF4" and it is not supported yet.
It is the same case with the ABS unit - it is "ABS Bosch 8/ESP", and it is not supported yet.
nightjedi
Post by nightjedi »
This ECU are supported in future versión of FES?
thanx
Yes, these modules will be supported.
nightjedi
Post by nightjedi »
thanx
