Parking Sensors Alfa 159
Hi Yani,
I installed the front and rear parking sensors (original) of my Alfa 159 1.9 JTDM and, from what I read, once the installation is complete you must "enable" on the node to get the distance on the display panel;
can you help me with this?
Thanks.
Bye, Andrea.
Thanks.
Bye, Andrea.
Re: Parking Sensors Alfa 159
I think that the first thing to try in this case is PROXI Alignment...
Hello Yani,
the alignment procedure proxies I've already done and this has solved only the lighting of the speedometer.
The display on the instrument panel was not able to activate it.
I think it's the same problem activating the cruise control indicator.
A friend, who'd turned the light on the cruise control, had explained to me that you had to write a
bit in the body computer: I thinkwe have to to do the same thing to solve this problem .
Waiting for one of your kind response I greet you and thank you for your kind reply.
Hi, Andrea
Hi, Andrea
Ok, I will need a PROXI report from a car with this option and a PROXI report from a car without this option.
My car has this option. The proxi report from my car can be found in Alfa 147 closing windows discussion.
Ok, this is good, I have your data. Now I need a report from @Baleta68 ...maunu wrote:My car has this option. The proxi report from my car can be found in Alfa 147 closing windows discussion.
Hello Yani,yani wrote:Ok, this is good, I have your data. Now I need a report from @Baleta68 ...maunu wrote:My car has this option. The proxi report from my car can be found in Alfa 147 closing windows discussion.
how do I get the proxi report from my car With FES?
I can not find any option to generate the requested report ....
Hi Yani,yani wrote:Ok, this is good, I have your data. Now I need a report from @Baleta68 ...maunu wrote:My car has this option. The proxi report from my car can be found in Alfa 147 closing windows discussion.
I am attaching pictures of the screens that I think are important.
If you need anything else let me know.
Hello, Andrea
Baleta68,
You need to setup the log folder and then attach the log file.
......Here are the filesyani wrote:Ok, this is good, I have your data. Now I need a report from @Baleta68 ...maunu wrote:My car has this option. The proxi report from my car can be found in Alfa 147 closing windows discussion.
- Imagine proxi.rar
- (513 Bytes) Downloaded 461 times
