The problem with an error
cder
Post by cder »
Hello, please help
What's wrong? What is damaged?
http://www.fotosik.pl/pokaz_obrazek/5f6 ... f89ac.html
Fiat brava 1.4 12v.
thank you.
Re: The problem with an error
Please send a report (from the red Send Report button) after reading the error and disconnecting from ECU.
cder
Post by cder »
Yani - I sent a report from the session.
These ols ECUs have very strange behaviour and very incomplete documentation and all of it is in Italian.
There no info about error code FF, but I think that error code FF means that there are no errors.
So, everything is ok with your car.
cder
Post by cder »
Yes but the car fires do not, it means it is mechanically damaged?
I have no idea... The error code FF simply does not have any explanation in the MA 1.7.3 document that I have.
kobra
Post by kobra »
Yani geschätzten schreibe Ihnen in Bezug auf die Fehlermeldung, dass zauwarzyłem FF, dass es scheint in der Bosch Mono Injection MA1.7.3 sicherlich die LPG erscheint. Ich vermute, dass dies eine Folge der Umstellung auf Flüssiggas auf Benzin, weil es eine Sonde Fehler übersieht nach dem Einschalten wieder FF ist.
EnIgMa
Post by EnIgMa »
Yani,
if you need to translate something from italian, let me know :)
