Bravo 2.0 155 Iso problem
Rayman19876
Post by Rayman19876 »
Hey there,
If i connect my ecu to my laptop, i use a elm327 v1.4 usb to obd16-pins, thats connected whith obd16 to alfa/fiat/lancia 3-pins, whith only the red cable for on the battery.
There is no black cable on this one. I can communicate whith the ecu, it only gives the error that the iso is nog right.
I'v chosen the fiat Bravo/brava '99 155 20v, my bravo is a fiat bravo 2.0 20v 155 hgt, 2001. It should be the right one i think.
It also brings up the ''latancy too high'' message.
Can anyone help me getting this right. I Also can't use it to read out the abs or airbags.
Re: Bravo 2.0 155 Iso problem
For "latency to high" see this topic:
viewtopic.php?f=5&t=2040&p=5805&hilit=kwp2000#p5805
And for "ISO code not right" - I think that ECU you selected is not the right one. Maybe your ECU is not supported yet?!? :roll:
In general you can work just fine with other ECUs but each time you will get this error message "ISO code not right"! ;) Just ingore the message...
Rayman19876
Thanks, i"d read about the high latancy. I think i can work that out. Next time i"l ignore the iso error.
I wil order a vagcom cable whith the switch, so i can use it for abs, airbag.
Then i can work out the faults in the system.
