This interface is not compatible with ELM 327 1.3!
fr00d
Post by fr00d »
I'm getting this error and don't know if it's just a wrong adapter or if there's anything broken.
RESPONSE: ERR94
WARNING: This interface is not compatible with ELM 327 1.3!
Will not connect to any CAN module.
This is what Multiecuscan 2.7.2 is telling me.
At the beginning the ATZ Command gets the answer: ATZELM327 v1.4a
Does Multiecuscan 2.7.2 not support ELM327 v1.4a Interfaces or am I doing anything wrong?
greetings
Andreas
ivica21
Re: This interface is not compatible with ELM 327 1.3!
Post by ivica21 »
Try to change port and do test.Maybe your elm interface is faulty.
ELM327 v 1.4
instinktus
Post by instinktus »
hello,
i have the same problem with my elm 327 interface.did you found the problem?
thanks.
ivica21
Post by ivica21 »
Try to remove this resistor connected between CAN-L and CAN-H.And if it does not work then the problem is elm327 chip.
ELM327 v 1.4
