Multiecuscan Alfa 159 JTD 2.4 20V
rickie_20
Post by rickie_20 »
Will this software show me how clogged the DPF in %
also will it show me data such as last time a regen was done?
Will it safely do a forced regen?
Would I need to purchase the software or would the trial do, and what cables would be best to purchase
Many Thanks for any information
Re: Multiecuscan Alfa 159 JTD 2.4 20V
Your engine has the Bosch EDC16C39 CF4 ECU same as on my Fiat Croma.
Fiat ECUScan will do all you are asking about and much more.
Please see here: http://multiecuscan.net/SupportedVehiclesList.aspx
This clearly shows that ONLY the engine ECU is supported in the free version. Good news is that the functions you are after are all engine ECU functions.
Only cable you will require for the engine ECU is either a simple KKL cable or an ELM interface. Neither of these will need modifying.
If I were you I would go for the ELM interface as that will give you CAN Bus support and access to all the other modules listed for your car. According to the chart on the above link then to connect to your ABS system then you will need Adapter Cable 1.
rickie_20
Post by rickie_20 »
Thats clears that up, Thanks..... Ordered a cable (like a tw@ from hong kong)
Will have a look at the software, and if its as good as what I am reading, I would hesitate in shelling out in the £50 it costs
Cheers again
