Since two weeks I got a little problem with my fiat punto 1.2 8v 60 KM 2001r engine started only with cable connected to pc FES.When I disconnect the cable engine never starts.Fault codes not found, but I can discover something after Parameters as follows:
Universal code - NOT RECEIVED
ECU programmed - NOT PROGRAMMED
Engine Start Permission - NOT ALLOWED
Phonic Wheel Status -  FAULTY
SW version - 00
When the engine starts the Phonic Wheel Status becomes OK.
I have already changed the Crank shaft sensor and made fonic wheel adaptation reset and the adaptation procedure acc to FES and the EOBD control light haven't stopped so I couldn't finish the adaptation.
Could you kindly explain how is with phonic wheel status just before start up.Should be faulty or OK.
Please replay I'm already getting mad
I've checked everything I could check.
