alfa 159 1.9 jtdm service reset
cambio
Post by cambio »
Guys, can't seem to find service reset on multiecuscan. using obd1.4 lead, all connects ok etc.
in 'f7 - adjustments' i have listed :-
oil replacement
reset self learn
injector code cyl 1 -2- 3-4
part filter replacement
particle filter regen
tried oil replace but it only clears the oil error message, doesnt seem reset service interval?
have set units to km and tried but doesnt seem to make any difference
using v2.7.2 which is the latest
any ideas or guidance? if anyone has done this please let me know!
thanks all - great tool otherwise, probably perfecct once i fugure out how to use it properly! :)
Re: alfa 159 1.9 jtdm service reset
Service Reset is in the Instument Cluster/Head. CAN bus connection required.
cambio
Post by cambio »
? not sure what that means. can you advise what to do when connecting?
Select the "Service" function in the list of modules (Engine,ABS,Airbag,Body,Service etc)
