PROXI ALIGNMENT TIP
dopsleutel13
PROXI ALIGNMENT TIP
Post by dopsleutel13 »
All models BT
021.10
9910119 1 AE PROXI ALIGNMENT
CUSTOMER'S REPORTED FAULT
None.
The fault can be checked only at the workshop, after replacing a component requiring a Proxi procedure.
TECHNICAL CAUSE
Impossible to carry out PROXI alignment.
OPERATION
Check by EXAMINER the SW release of the BCM control unit (Body Control Module):
if it is after release F07/08, continue troubleshooting.
If the SW is before or equal to release F07/08, perform a battery Disconnection/Reconnection.
If the fault is not solved, continue troubleshooting.
CLAIM REPORT DATA
Version
Operation
Piece
Fault
Position
Time allowance
All models in question
9910119 1 AE -0.20
Sheet Model Subject Release date Date of last update Closing date Notes
021.10 Alfa Giulietta PROXI ALIGNMENT 22/07/2010
