today i want to clear airbag errors in my punto II 1.8 HGT.
i have FES 2.7.2 and get this: "your car has 3 pin connector..." and i can not connect to airbags in this 2.7.2 version.
old FES 2.6 works fine and i've cleared errors now.
it looks for some BUG in FES 2.7.2 or maybe even FES 2.7
"use 3 pin adapter"
Re: "use 3 pin adapter"
I think there is no bug.
When you try to connect to the airbag you get the following message:
CONNECT ADAPTER 2 (RED)
If your vehicle has a 3-pin connector then connect a 3-pin adapter only!
Press Y To Continue or Press N To Abort
This is just an informational message. You have to press Y to continue.
Also, you can turn off this message from Settings.
But this is false massage.
There is no 3 pin connector, isn't it?
