DPF COUNTER Multipla JTD
vindiv8
Post by vindiv8 »
Before I make the investment on the software and a cable, could someone please confirm that you can clear the oil degradation light (dpf counter) on a Multipla JTD. Can you also confirm it is the ELM cable I would need for this? Thanks in advance, a frustrated Multi owner ;)
luks
Re: DPF COUNTER Multipla JTD
Post by luks »
i'm waiting for solution too...
I have the registered version and have run it in Test Mode on BOTH the Multipla 1.9JTD engine ECUs and can see NO DPF/Oil Change support functions yet.
Yani is implementing things as fast as he can but I have no idea if/when the functions you require will be supported.
