Hi all.
I have a problem with test the siren and other component of the alarm.
If I check the siren, alarm sensor I have a message " Can't run this test. Abnormal conditions to run this test" but in Polish language "Nie można wykonać. Nieprawidłowe warunki do uruchomienia tego testu !"
I don't understand what it means.
Siren in my car don't work and I looking for where is the cause.
Operating mode alarm is "world" (5).
Type of the siren (Body computer ?) - M751A
If I connected it to power the car can hear only four short beeps and nothing
						"Can't run this test."
Re: "Can't run this test."
I can only say, that the polish translation of this message is ok
 Each test has some specific conditions in which it can be performed, by condition it is meant the state of specific car components, like for some ECU tests the engine must be running, while for others - engine must be stopped. I have no idea what condition must be fulfilled to perform siren test, but when you tried this conditions were not met.
hm... ok
tnx.
						tnx.
As for the conditions, to run that test the doors must be closed.
