I got problem with proxy alignment in Fiat Panda 2004 1.1. I changed instrument cluster and got flashing milage, abs and brake light always on etc... tried aligning with punto 99 1.2 and punto 03 1.2 to no success
Here are my messages:
on scan:
on port test:Scanning ...
Engine
Magneti Marelli IAW 4AF/4EF/59F/5AF EOBD Injection
ISO Code: 0D 07 C1 83 AD
Body
UNKNOWN/UNSUPPORTED
ISO Code: 40 83 97 83 22
and here log from alignment probe:Scanning ...
ELM 327 interface found at port COM14, speed 38400bps
Latency Too High!!!
COMPLETED
COMPLETEDReading CAN configuration data ...
CAN CONFIGURATION DATA:
00 00 00 0F 00 00 00 0F 00 00 00 0C 00 00 00 08 00 00 00 00
00 00 00 0F 00 00 00 09 00 00 00 0F 00 00 00 09 00 00 00 01
33 32 31 36 39 30 30 30 31 38 35 4F 55 54 50 55 54 4A 49 54 20 20 03 09 25 0F 00 00 00 09 00 00 00 10 00 00 00 00 01 14 00 00 00 04 06 01 00 00 00 00 00 00 10 00 00
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
11-03-01 20:25:19
CONNECTED TO:
FIAT PUNTO '03 1.2 8V
Body Computer Node (NBC):
Engine Control Node (NCM):
Electric Steering Node (NGE):
Dashboard Node (NQS):
EXECUTING ADJUSTMENT...
Writing to module: Body Computer Node (NBC)SUCCESS!
Writing to module: Dashboard Node (NQS)FAILED!
FAILED TO EXECUTE
