Problem Connecting Hitachi MPI injection (pre98)
Ralf A.
Post by Ralf A. »
Hallo,
my name is Ralf and i am owning a Fiatcoupe 1.8 16V build in 1996.
I have tried to connect to the Engine - Management without success.
Im using a VAG KKL Interface Autodia K409.
When i use the F11 scanfunction, i get the message:
Scanning.....
Motorsteuerung
ISO Code: 45 85 83 94 B6
Fertig
But im unable to connect.
To varify the function i have connected the Interface to the ABS. This works fine. Multiecuscan connect to the ABS and everything works like expected.
Why does the FES not connect to the engine management. Hardware seems to work perfekt. It is also able to regognize the ID, why cant it communicate?
Thank you for your help
Ralf
ubohli
Re: Problem Connecting Hitachi MPI injection (pre98)
Post by ubohli »
Good morning,
My car is a Barchetta from early '96, and I have the same problem. The scan tells me:
The OS is Windows VISTA SP2. I send a report today 27.02.2011 at 9:30
The adapter is also a VAG-KKL interface
regards
Uli
Ralf A.
Post by Ralf A. »
Hallo,
one information which maybe helpfull:
There is no connection to the L-Line inside the 3pin connector of the MPI.
It has only two wire: Ground and K-Line
Ralf
delta-c
Post by delta-c »
does it work by now?
Got the same problem with a Lancia Delta 836 1.8 16v Hitachi MPI (ISO Code: 45 85 83 94 B6) from '97/'98.
The scan works, but EcuScan cannot connect.
Operating systems: Windows 7, Xp
KKl-Cable and 3-Pin-adapter
Does anyone have a solution?
Kind regards,
Simon
Abbadon
Post by Abbadon »
I have exactly the same Problem.
Hopefully the problem will be solved soon.
I know about this problem and I'm trying to fix it. It happens only with this Hitachi ECU.
byrrt
Post by byrrt »
Hi Yani!
Can You tell me when you relase next version working witch Hitachi MPI?
Thanx
Peter
byrrt
Post by byrrt »
New version (2.8) still not working with this ECU :?
Ralf A.
Post by Ralf A. »
Still the same shit with the 2.8.
Scan ok, but no connection with the Hitachi.
:cry: :cry: :cry:
byrrt
Post by byrrt »
2.8.1 - same problem
