HELP!!
Posted: 22 Feb 2011, 16:40
by derekwatt5
ok
i can connect to the engine ecu! it finds the airbag ecu! it finds the abs ecu! why does it not find the boady ecu? and when i try to connect to the abs ecu! it does then after a couple of seconds it boots me out???
Re: HELP!!
Posted: 22 Feb 2011, 17:14
by i_andrei_g
You should probably tell on what car you are trying to connect and what interface you are using.
Without this i don't think anybody will be able to help you
Re: HELP!!
Posted: 22 Feb 2011, 18:16
by derekwatt5
ok its a fiat stilo 1.6 active!
i have more problems! im using this cable with 4 dip switches! it came with software with a driver on it VACOM! when i try to install the driver it does not work?? it installs the usb but when it comes to the serial port it crashes??
even when i had it working the vacom program did not find the usb?? ANYONE GOOD WAY PCS??
Re: HELP!!
Posted: 22 Feb 2011, 19:30
by i_andrei_g
For Body Computer you need an ELM 327 vs 1.3a, with a modified Vag Com 409.1 cable you will be able to connect only to Engine, ABS/ASR/ESP and Airbags.
First check if you have the right driver for the interface installed. You can get them from
http://www.ftdichip.com/Drivers/VCP.htm.
There are 2 types of drivers for the ftdi chip in your interface VCP and D2XX, you need the VCP (virtual com port driver).
After installing this driver you have to set the latency timer to 1 check it how it's done here
http://multiecuscan.net/HowToUse.aspx
To be honest sounds to me more like you have problems with your interface, check with another one if it works, or check if your's works on another car.
Re: HELP!!
Posted: 22 Feb 2011, 20:52
by derekwatt5
ok!
i now can read the engine, abs, air bags, and power steering!
following set to the on position
dill switch 1 engine
dill switch 2 air bags
dill switch 3 abs
dill switch 4 power steering
so how the hell do you get to read the body ecu???
Re: HELP!!
Posted: 23 Feb 2011, 00:30
by Judge_Joolz
You dont with a VAG Com cable - you need an ELM 327 cable.
See post about 3 up..
Best regards
JJ
Re: HELP!!
Posted: 28 Feb 2011, 15:19
by derekwatt5
ok! got it all connected! now its asking me for a 6 diget security code to program a key????? where do i get that??
Re: HELP!!
Posted: 28 Feb 2011, 15:59
by alfa156sarajevo
derekwatt5 wrote:ok! got it all connected! now its asking me for a 6 diget security code to program a key????? where do i get that??
I think you need a CODE CARD for that! You should get this card with your car keys (with your car)!
If you do not have that card you have to order it but ONLY from official ALFA/ FIAT/ LANCIA dealer!!!
I have the same problem. I also have to order this CODE CARD from official dealer but it is little bit expensive!
It is about 65€!
