today we had some difficulties with Alfa 159 3.2 JTS Q4. I think that the fuel system was frozen due a -20 degree celsius wheather.
I did manage to read error codes with Alfa 156 V6 eobd engine diagnostics, but only some of the acutator tests worked with the ecu.
Is this ecu being added to the next release?
Alfa 159 3.2 JTS engine ecu support
Re: Alfa 159 3.2 JTS engine ecu support
I am interested in full support for the Brera/159 3.2v6.
Is my first post too soon to beg?
Please, I am begging you my car is unsellable with the mystery engine sound I just need to get to the variators if at all possible!
Further to my previous post, i would like to try and fuirther justify this request by directing you to this forum thread, which has over 100 posts;
http://www.alfaowner.com/Forum/alfa-159 ... start.html
The dealers have failed to adequately investigate this problem. This problem needs a solution, and the variators need to be discounted. To do this it is necessary to monitor the engine paramters/
Again, if you have any ability to add this feature a group of 159/brera owners would benefit from your work.
