Alfa 145 and M2.10.4 - some weird things
lukee
Post by lukee »
first of all I want to say thank you for this great software! I've experienced few problems with it during my yesterday's scanning of my Alfa 145 1.8 TSpark 16V equipped with Bosch M2.10.4 motor management. Here they are:
1. after ECU is connected I am getting info message, that my ECU's ISO code is invalid. What does it mean?
2. after scanning ECU's failures register, here are some errors without a proper description:
- error number: 3C (Found interference / missing signal) / intermittent / 8
- error number: 0E (value too high) / intermittent / 147
- error number: 0E (open circuit) / intermittent and present / 170
3. Actuator's test: I am able to run it, but actuators aren't performing (with other diagnostics, Uniscan, they are)
4. Real time parametres: all values aren't stable, but oscilating... i.e. battery voltage jumping beween 6 and 80 V
5. After connection is established, the program inform me about high link latency.
I'm using VAG-COM cable (MAX232 chip inside) with serial interface to COM1 port, I set transfer rate limitation to 9600 bps. Thanks for help!
