Alfa 156 2002 Dash Change
alpha
Post by alpha »
I have a VAG KKL which reads the Engine Airbags ABS perfect with FES 2.6.1
I have changed the dash clocks and need to set the correct odometer reading in the ECU on to the new speedometer.
Do I need a ELM 326 to adjust the odometer with FES ?
johnboyhgt
Re: Alfa 156 2002 Dash Change
Post by johnboyhgt »
As far as i can remember the mileage cannot be updated on 156 !
Picoscope 4223 - Automotive Oscilloscope
Gendan Engine Check Pro - Registered
Fiat Ecu Scan - Registered
alpha
Post by alpha »
Ok
I thought so.
What does the ELM do on the CAN that a KKL VAG cant do ?
alpha
Post by alpha »
I see its compatible I was wanting to know the difference between the two leads.
