INVALID ISO CODE - ERRATIC VALUES RED
ALFA166V6TB
Post by ALFA166V6TB »
Hi all,
I have recently got an ALFA 166 2.0 V6 TURBO Year 1999 with 135000 km), and now I am getting in troubles with the engine. It is running very poorly.
I have bought an ELM327 v1.4 USB interface to look at ECU defaults and values.
I am currently trying Multiecuscan (trial) before to invest in the full version. But I am facing two problems:
- ISO code is invalid according FECUS,
- ISO code scanned is different from the one expected by FECUS,
- values red are absolutely meaningless (ex: Speed varies from 1à to 100 in one second !!!),
- FECUS Status bar complains about interface slowness.
Here attached screenshots of the two ISO codes.
What should I do to get everything in order ?
Thanks in advance for your help.
This is what is expected by FECUS
FECUS InvalidISOcode.jpg (62.26 KiB) Viewed 4520 times
This is what scanning says
FECUS ECU and ISO.jpg (9.95 KiB) Viewed 4520 times
ALFA 166 2.0 l V6 Turbo
Super Edition
Aurora Irridescente paint
Year 1999 - 135,000 kms
Re: INVALID ISO CODE - ERRATIC VALUES RED
This is SIMULATION mode. This is not real data from the vehicle. Try pressing F10 or clicking with the mouse on Connect button.
CTRL+F10 - connection in simulation mode
F10 - normal connection
ALFA166V6TB
Hi Yani,
Thanks for your attention.
Well, I did simulation mode because otherwise I got the message
This module requires registered version. You must use simulation mode by typing CTRL-F10
and was disconnected forcibly.
Is it normal behavior ?
If yes, then I cannot try the software in real conditions.
I am ready to buy one licence, but how to be certain that it will work as expected ?
Regards.
Super Edition
ALFA166V6TB
OOOOPPSSSSSSS,
I just discover that Bosch Motronic ME 2.1 (2.0 V6 TB) is only supported by Registered Version.
I did not pay attention to red colored lines in SUPPORTED VEHICLES/SYSTEMS list at http://www.multiecuscan.net/SupportedVehiclesList.aspx.
Sorry for that but it is not so evident for daltonian people. :o
I am going to buy the license, so (no choice). :x
Super Edition
