Hi All
I've just done the CAN alignment procedure with multiecuscan on my 2.0 Alfa 147 as I have the flashing odometer issue and the log files say that the dashboard failed with the error below.
Writing to module: Dashboard Node (NQS)FAILED!
The full log file is copied below but can anybody suggest what the problem might be with the dashboard to cause this error?
Many thanks
Paul
Log file below:
CAN CONFIGURATION DATA:
00 00 17 6B 00 00 17 6B 00 00 00 41 00 00 00 00 00 00 00 00 00
00 00 17 6B 00 00 07 09 00 00 17 6B 00 00 07 09 00 00 07 01 00
34 36 37 39 33 39 32 36 20 20 20 44 54 53 49 45 45 50 44 45 20 20 00 07 11 6B 17 00 00 09 07 00 00 49 00 00 82 26 07
Body Computer Node (NBC)
Engine Control Node (NCM)
Brake System Node (NFR)
Driver Door Node (NPG)
Boot Node (NVB)
Climate Control Node (NCL)
Steering Angle Sensor Node (NAS)
Boot Node (NVB)
Boot Node (NVB)
21/01/2011 12:12:09
CONNECTED TO:
ALFA 147 2.0 TS 16V
Body Computer Node (NBC):
Engine Control Node (NCM):
Dashboard Node (NQS):
Receiver Radio/Radio Navigator Node (NRR/RMN):
Brake System Node (NFR):
Driver Door Node (NPG):
Boot Node (NVB):
Climate Control Node (NCL):
Steering Angle Sensor Node (NAS):
Boot Node (NVB):
Boot Node (NVB):
EXECUTING ADJUSTMENT...
Writing to module: Body Computer Node (NBC)SUCCESS!
Writing to module: Driver Door Node (NPG)SUCCESS!
Writing to module: Boot Node (NVB)SUCCESS!
Writing to module: Climate Control Node (NCL)SUCCESS!
FAILED TO EXECUTE
CAN Proxi Alignment procedure dashboard failure help please
Re: CAN Proxi Alignment procedure dashboard failure help ple
There is a BUG in FES ver. 2.6.1! I had the same problem! Just send a e-mail or private message to Yani and he will help you!sponcom wrote:Hi All
Many thanks
Paul
