I mentioned on the open forum the problems communicating
with my sons 2004 16v 1.4 Punto Sporting. Still have problems
but have just posted reports now.
kkl interface
Gendan 1.3a interface with both 6 and 14 can
and isolated 1 and 9 can with can module scans.
Only the ABS available no other modules available????
Perhaps you can advise
Thanks John
						2004 1.4 16v Punto Sporting
Re: 2004 1.4 16v Punto Sporting
I see the logs...
It seems that you have some problem with the physical connection.
Is it possible that the OBD connector on this punto is not making a good contact? Or there is something that is causing noise on the CAN bus? Or probably bad earth?
The interfaces begin to receive some data from time to time but after a few bytes throw a checksum error.
Also, I noticed that in the ABS module you have a communication error:
C1107 - Lost Comm. with IPC Control Module
						I see the logs...
Thanks Yani
I know which way to try and solve the problem now.
Thanks John
Thanks John
