Page 1 of 2
ABS Stilo JTD ???
Posted: 24 Nov 2009, 20:03
by kecka
Re: ABS Sitlo JTD ???
Posted: 25 Nov 2009, 15:06
by yani
I have tested the program on Stilo JTD with ABS 5.7 (without ASR) yesterday and it worked perfectly.
Anyway, I'm doing some fixes on the communication protocol timings now. Will post an updated version in a few days. Hope it will work for you.
Posted: 25 Nov 2009, 18:48
by kecka
Posted: 25 Nov 2009, 18:59
by yani
Are you sure that your serial port is configured properly? It seems that it is not.
You need to lower the buffers to minimum and set the latency to minimum (for usb cables).
Posted: 25 Nov 2009, 19:47
by kecka
I have a cable to the serial port........
I have it set as follows......
Posted: 26 Nov 2009, 05:55
by yani
Your configuration seems to be correct.
Posted: 26 Nov 2009, 15:29
by kecka
if you have new information to Write.......
I'll go immediately to test....
Re: ABS Stilo JTD ???
Posted: 07 Dec 2009, 18:55
by chudystilo
I have problem like a KECKA from Czech. Connect via BOSCH EDC15C7 CF3/EODB Diesel Injection is no problem, perfectly and make me a happy
, But connect via BOSCH ABS .... is impossible. Display - disconnected
Posted: 07 Dec 2009, 19:01
by yani
Did you connect the cable to pin 1 of the ODB connector? You need to connect it to pin 1 for the ABS.
Posted: 07 Dec 2009, 19:08
by chudystilo
Yesterday I connect Pin 1-7, and the problem with ABS communication.
Connected and disconnected triple times and nothing.
Flashing ABS/ASR icon. CONNECTED IS LOST and again try to connect. That`s all
Cable USB, FIAT STILO 1.9 JTD 2002
