ABS Stilo JTD ???
kecka
ABS Stilo JTD ???
Post by kecka »
Thank you for the program a good ;) ;) ;) ;)
But I have a problem, you can not connect to the ECU ABS (Stilo JTD year 2002). As begins to connect and begin flashing lights ABS and ASR, But the connection does not ??????
Someone knows what it can be ???????
The ECU engine together without any problem :) :) :)
Excuse my English, I write from the Czech Republic :) :) :) :)
Re: ABS Sitlo JTD ???
I have tested the program on Stilo JTD with ABS 5.7 (without ASR) yesterday and it worked perfectly.
Anyway, I'm doing some fixes on the communication protocol timings now. Will post an updated version in a few days. Hope it will work for you.
kecka
Post by kecka »
That would be great :) :) :) :) :)
I also tried today Marea 2.4 JTD program immediately connect, but immediately disconnected. Made after each connection :( :( :(
It will be in the program about an error..... :( :(
Are you sure that your serial port is configured properly? It seems that it is not.
You need to lower the buffers to minimum and set the latency to minimum (for usb cables).
kecka
Post by kecka »
I have a cable to the serial port........
I have it set as follows......
Your configuration seems to be correct.
kecka
Post by kecka »
if you have new information to Write.......
I'll go immediately to test.... :) :) :) :)
chudystilo
Re: ABS Stilo JTD ???
Post by chudystilo »
I have problem like a KECKA from Czech. Connect via BOSCH EDC15C7 CF3/EODB Diesel Injection is no problem, perfectly and make me a happy :) , But connect via BOSCH ABS .... is impossible. Display - disconnected :(
Did you connect the cable to pin 1 of the ODB connector? You need to connect it to pin 1 for the ABS.
chudystilo
Yesterday I connect Pin 1-7, and the problem with ABS communication.
Connected and disconnected triple times and nothing.
Flashing ABS/ASR icon. CONNECTED IS LOST and again try to connect. That`s all :cry:
Cable USB, FIAT STILO 1.9 JTD 2002
