seat belt beep off problem
ttlogan
Post by ttlogan »
Hi Yani!
Formerly the seat belt beep turned off multiecuscan the program, and then later saw that the car's display can be switched on and that it is done.
But as soon as the car turned on, this menu item disappears. Multiecuscan program does not turn it off again!
Fiat stilo 1.4
ttlogan
Re: seat belt beep off problem
Post by ttlogan »
HI yani!
I'm back! The 2.4 version works!
The next versions are not good!
Please fix it!
Fiat stilo 1.4
So, the "Seat belt buzzer off" function in FIat Stilo does not work properly in Multiecuscan 2.6.1, but works properly in 2.4?
What type of interface do you use?
mattydr67
Post by mattydr67 »
Maybe it will works good in the new realise.
