Hi yani.
I have installed a Connect Nav+ to my stilo.
I use to have the blinking km error until someone from Italian forum told me to put a small interruptor to hold the power to the connect nav about 5 sec until the check finishes. That worked very well.
So my next 1 million dollar question is. If I remove the interruptor and try the proxy alignment do you believe that I can get rid of the annoying blinking odometer?
Best regards
Stilo Connect nav+
- Contact:
Re: Stilo Connect nav+
Yes.ionio-zante wrote: If I remove the interruptor and try the proxy alignment do you believe that I can get rid of the annoying blinking odometer?
BAS
