i m new here. I ha ve question. i have a stylo 1.6 16v .
how can i know which model i need?
Magneti Marelli IAW 5NF EOBD Injection KLELMOBDKey
Magneti Marelli IAW 5NF EOBD Injection (Outside EU version) KLELMOBDKey
Bosch ABS 5.7 KL 1ELM 1OBDKey 1
Bosch ABS 5.7 ASR/TC KL 1ELM 1OBDKey 1
Bosch ABS 5.7 VDC KL 1ELM 1OBDKey 1
Bosch ABS 8 KL 1ELM 1OBDKey 1
Bosch ABS 8 VDC KL 1ELM 1OBDKey 1
SIEMENS MY 99 Airbag (2F-2P-2L-2T-I-C) KL 3OBDKey 3
SIEMENS MY 99 Airbag (2F-2P-2L-2T-I-S-C) KL 3OBDKey 3
Another question, is it possible to encode additional key to my car (key who permitme to open car at distance)?
thanks you
Fiat Syto 1.6 16v Model?
Re: Fiat Syto 1.6 16v Model?
You need VAG COM KKL interface and ELM327 ver. 1.3 or newer to connect you car with FES program.
If you want to connect to ENGINE ECU then select "Magneti Marelli IAW 5NF EOBD Injection". If you living are outside from Europe (example: America, Africa...) then you need to select "Magneti Marelli IAW 5NF EOBD Injection (Outside EU version)".
If you want to ABS or AIRBAG ECU first you need to press button SCAN and after 60 sec. you will get information which ASB and AIRBAG system do you have. After that just select that option and you can connect to those modules.
But if you do not do this you can try each to connect each of these modules individually:
SIEMENS MY 99 Airbag (2F-2P-2L-I-C)
SIEMENS MY 99 Airbag (2F-2P-I-C)
SIEMENS MY 99 Airbag (2F-2P-I-S-C)
SIEMENS MY 99 Airbag (2F-4P-4L-2T-I-S-C)
You can not do anything bad to you car!
Cheers
Cheers
excuse me to post he same question
You CAN NOT code any additional keys to your car! You can only EDIT or MODIFY remote control option on your key - lock and unlock option on the car with your key!falco33 wrote:excuse me to post he same question
one of my key have lost the code. There is no solution with this method?
how do fiat solve thisproblem?
I do not think so!falco33 wrote:one of my key have lost the code. There is no solution with this method?
Send back to official Fiat dealer and they do all coding!falco33 wrote:how do fiat solve thisproblem?
