Proxy Alignment does not fix the CANCHECK problem on the CD/Radio in my Panda '03 1.2 8V.
Yani said that I could use the Punto Proxy Alignment Proceedure in Punto '03 or '99 1.2 8V as Proxy Alignment is not available under Panda '03 1.2 8V.
The proceedure writes and completes ok but does not see the M094 (NRR) Radio Node.
The Radio node does not appear on a Scan of available ECUs.
I have a feeling it is because the ISO for the Body node comes up unsupported on a Scan.
The Body Computer Node is:- ISO Code 40 83 19 83 34 for a Fiat Panda 2004 1.2 8V Petrol.
The Punto 99 & 03 1.2 8V both have a different Body ECU to the Panda and are both supported under FES.
The FES log is below:-
CAN CONFIGURATION DATA:
00 00 00 4F 00 00 00 4F 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 4F 00 00 00 09 00 00 00 4F 00 00 00 09 00 00 00 09
33 32 31 36 39 30 30 30 33 37 30 4F 55 54 50 55 54 4A 49 54 20 20 04 05 07 4F 00
00 00 09 00 00 00 91 A0 00 00 00 01 26 00 00 00 04 06 01 00 00 00 00 00 00 13 01 00
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Brake System Node (NFR)
05/12/2010 21:45:03
CONNECTED TO:
FIAT PUNTO '03 1.2 8V
Body Computer Node (NBC):
Engine Control Node (NCM):
Electric Steering Node (NGE):
Dashboard Node (NQS):
Brake System Node (NFR):
EXECUTING ADJUSTMENT...
Writing to module: Body Computer Node (NBC)SUCCESS!
Writing to module: Engine Control Node (NCM)SUCCESS!
Writing to module: Electric Steering Node (NGE)SUCCESS!
Writing to module: Dashboard Node (NQS)SUCCESS!
Writing to module: Steering Wheel Controls Node (NVO)SUCCESS!
Writing to module: Receiver Radio/Radio Navigator Node (NRR/RMN)SUCCESS!
Writing to module: Brake System Node (NFR)SUCCESS!
Writing to module: Info-Telematic/Convergence Node (NIT/NCV)SUCCESS!
Writing to module: Driver Door Node (NPG)SUCCESS!
Writing to module: Boot Node (NVB)SUCCESS!
Writing to module: Climate Control Node (NCL)SUCCESS!
Writing to module: Automatic Transmission Node (NCA-NCR)SUCCESS!
Writing to module: Steering Angle Sensor Node (NAS)SUCCESS!
Writing to module: Parking Brake Control Node (NPB)SUCCESS!
Writing to module: Ceiling Node (NIM)SUCCESS!
Writing to module: Side Acceler./Yaw Node (NYL)SUCCESS!
Writing to module: Adaptive Cruise Control Node (NAC)SUCCESS!
Writing to module: Passenger Door Node (NPP)SUCCESS!
Writing to module: Driver Seat Node (NAG)SUCCESS!
Writing to module: Assisted Braking Node (NBA)SUCCESS!
Writing to module: Passive Entry Node (NPE)SUCCESS!
Writing to module: Steering Lock Node (NBS)SUCCESS!
Writing to module: Gearbox Selector Node (NSC)SUCCESS!
Writing to module: Passenger Seat Node (NAP)SUCCESS!
Writing to module: Parking Sensor Node (NSP)SUCCESS!
Writing to module: Engine Signals Node (NSM)SUCCESS!
Writing to module: Airbag Node (NAB)SUCCESS!
Writing to module: Air Suspension Node (NMA)SUCCESS!
Writing to module: Roll Control Node (NRC)SUCCESS!
Writing to module: Self-adaptive Headlamps Node (NFA)SUCCESS!
Writing to module: Haptical Lane Feedback Node (HALF)SUCCESS!
COMPLETED
Does this mean that I will have to wait a bit longer or is there something else that I need to know please?
Regards ~ Chris
Proxy Alignment & CanCheck Panda '03 1.2 8V
Re: Proxy Alignment & CanCheck Panda '03 1.2 8V
Please can someone reply to my post or is it because I have a Panda.
Desperate Regards ~ Chris
I'm not 100% sure, but I think that this CANCHECK message is not related to the PROXI Alignment.
There are lots of topics about it on www.fiatforum.com
You can check this:
http://www.fiatforum.com/punto/13201-ca ... ssage.html
You can check this:
Many thanks for the reply Yani.
I know that CanCheck can be taken off by reprogramming an eeprom in the radio but I was hoping FES would be of use as Fiat use Examiner to correct this error.
Maybe I need an extra link cable or lead from the Body ECU to the radio to enable FES to remove CanCheck.
The manual shows the B-CAN connection to the radio via one of the 2 main plugs. The yellow small plug has no wires ?
*** Any Fiat Dealer Expert Techys out there please ? ***
