service reset 1.6 MultiJet MUSA 120ch
ragon
Post by ragon »
I use ECUScan 2.3.1 and do a service reset (comfort).
After the reset, the km service is 20000 km instead of 30000 and the oil lamp service blinking ever. Is the 2.3.1 make the DPF re-génération and reset the dashboard oil lamp.
Thanks. Ragon
Re: service reset 1.6 MultiJet MUSA 120ch
In diesel engines with DPF the Service Reset and Oil Change are separate funtions.
For the oil change reset look at the Engine "actuators" menu. There is/should be an Oil Change/Reset function.
Doing a forced DFP regen will not change the oil lamp status.
alex206cc
Post by alex206cc »
i have a musa 1,3 jtd but i have a problem with service reset, i can't connect for reset the body connect is ok..
ragon
Post by ragon »
s130 wrote:In diesel engines with DPF the Service Reset and Oil Change are separate funtions.
In Multiecuscan 2.5, for the model Lancia MUSA 1,6 MJET 16V, the menu "Engine" doesn't exist. Is there a possibility to use a other model of car.
Thank
