FES and M2.10.4 problem
HI! I have Fiat Marea Weekend 2.0 20V (same engine ECU in Lancia Kappa 2.0 20V and Coupe - Bosch M2.10.4) Alfadiag connect to this ECU without any problems using my VAG KKL cable but FES 2.5 (not registered) cant connect......I changed latency to 1 and 2- COM port 1 and 2 and dont have any result.....
could any one help with this problem ???
Re: FES and M2.10.4 problem
go to:
and you will see that ECU Bosch M2.10.4 is supported by the commercial version only!!!
Cheers
Cheers
