Spanish translations and CAN bus
Posted: 20 Nov 2009, 20:34
Hello:
Very good your work, thanks.
It's possible translate softwate to spanish language ???
I may help you with all translations, if you send text file, I translate all for you for free of course.
About CAN bus feature that you advertise that will add in new versions:
Which interface will may use to work with CAN bus and your software ???
Current VAG KL or VAG KKL do not support CAN bus, only K line.
It's possible you do it compatible with ELM327 chip, that support CAN bus ??
Do not know another universal interface that may support CAN bus, because of VAg-COM CAN bus interfaces only work with VAG-COM software,because of it use special processor to work only with VAG-COM.
Kind Regards
Kind Regards
