I have ELM 327 with USB connection and my laptop has USB ports only.
multiecuscan works with COM port only .
what shall I do to make it work .
thanks
ELM 327 WITH USB CONNECTION
Re: ELM 327 WITH USB CONNECTION
nothing.
your laptop will open a virtual COM port using a real usb one
Read this: http://www.multiecuscan.net/HowToUse.aspx
it will help you.
it will help you.
Just plug in your USB interface and install the driver.
Then start Multiecuscan and go to "Settings".
Check (mark) "Show available ports only".
Then select a "Serial port" from the list (There will probably be only 1 option available).
Select "ELM 327 v1.3+" as Interface Type.
Set Port Speed to 38400.
Click "Test" button.
thak you
I did not see that it makes a virtual com port .
problem is solved .
problem is solved .
