Multiecuscan 2.5 Language and Data language Files
OndraMarkow
- Contact:
Here is an 100% translated new version Czech translation
- Lang.rar
- (23.45 KiB) Downloaded 721 times
Fiat Marea Weekend 1.9 JTD 105 rv2000 Xenon look+Led,Boost control,EGR-OFF
Grande Punto 2010
VFR750 RC36
Grande Punto 2010
VFR750 RC36
Serbian translation of the FES 2.5 (Cyrillic
The beta version of Serbian translation of the FES 2.5 (Cyrillic)
Serbian.txt- The beta version of Serbian translation of the FES 2.5 (Cyrillic)
- (10.23 KiB) Downloaded 672 times
incredible
Re: Multiecuscan 2.5 Language and Data language Files
Could you give me a polish language to Ecu 2,5?
Or in this program is in 100% translate all to polish?
Here's a new Danish translation for Multiecuscan 2,5.
It has been rewritten in a better Danish language and most of the "Danglish" translated.
Papy
Papy
Danish.txt- Danish.txt
- (6.48 KiB) Downloaded 602 times
Greek translation of the FES 2.5
GREEK TRANSLATION FES.txt- (7.31 KiB) Downloaded 558 times
This greek file seems to have problem with the encoding.ianos wrote:Greek translation of the FES 2.5
hope now that its ok. .
GREEK TRANSLATION FES.txt- (7.62 KiB) Downloaded 568 times
There seems to be a problem with the encoding. The file has to be in Unicode.ianos wrote:hope now that its ok. .
Anyway, I converted the file using Windows' standard Greek encoding and saved it as Unicode. It looks fine now.
Greek.txt- Unicode Greek File
- (14.85 KiB) Downloaded 617 times
Here are two versions of the translation into Serbian for FES v2.5. You have two files Serbian.txt and Serbian-CIR.txt, put them in . In "Setings" choose between the "Srpski-LAT" or "Српски-ЋИР" depending on whether you want the Cyrillic or Latin script.
Soon, the translation into Serbian - Serbian.dat
C: \ Program Files \ Multiecuscan \ Lang \
Serbian-CIR.txt- Srpski ćirilica by Fiat-Dijagnostika.com
- (10.53 KiB) Downloaded 556 times
Serbian.txt- Srpski latinica by Fiat-Dijagnostika.com
- (13.48 KiB) Downloaded 576 times
many, many thanks for this!!!Bravo-JTD wrote:Here are two versions of the translation into Serbian for FES v2.5. You have two files Serbian.txt and Serbian-CIR.txt, put them in. In "Setings" choose between the "Srpski-LAT" or "Српски-ЋИР" depending on whether you want the Cyrillic or Latin script.Code: Select all
