Proxy Alignment
Proxy Alignment
Anyone with flashing odometer who wants to test the Proxy Alignment function?
I'm ready with this function and want to do some testing on different cars before the final release.
I'm also curious how it will work for the people who have retrofitted Connect Nav on Stilo.
ivica21
Re: Proxy Alignment
Post by ivica21 »
Can i test on Fiat punto 2003 and fiat doblo 1,9 2008 ?
ELM327 v 1.4
Re: Proxy Alignment
Yes, I think it will work. Although the body computers of thses cars are not supported yet.
Do you have a flashing odometer?
Betty_Swallocks
Re: Proxy Alignment
Post by Betty_Swallocks »
I'd love to test it Yani
My odometer is flashing because at some point in the cars history a satnav was removed and replaced with a standard cd head unit.
pirignogno
Re: Proxy Alignment
Post by pirignogno »
I added on my stilo the connect nav, parking sensors and automatic air conditioning, am willing to try if it works on my stylus.
Fiat Stilo 3 porte 1.9JTD Dynamic '03
mbtanner
Re: Proxy Alignment
Post by mbtanner »
Got an Alfa 147 TI (1.9 JTD 16V) with a flashing odometer (had it since we bought the car used). Willing to try and test!
illiac4
Re: Proxy Alignment
Post by illiac4 »
When i will install cruise control in my alfa 159 i will test this feature if it will allow to install cruise control. Is it safe to do this (flash)?
gdimassa
Re: Proxy Alignment
Post by gdimassa »
On my 147 1.9jtd. 8v sometimes it flashes and I never understood why, I will be happy to test it and mayne resolve the flashing problem.
Thx
azerty
Re: Proxy Alignment
Post by azerty »
I've just installed the new version of FES2.6 and using a bleutooh elm1.3a (clone) on the alfa 159 16V JTD
Everything works well...exept PROXI ALIGNMENT.
I get the message "no connection possible"
When I trie to "connect" in simulation mode (CTRL F10)... I get the same message. The message is the same when I'm changing the interface type (in simulation mode).
Houterman
Re: Proxy Alignment
Post by Houterman »
azerty wrote:I've just installed the new version of FES2.6 and using a bleutooh elm1.3a (clone) on the alfa 159 16V JTD
i had the same issue,
you have to change the data language into englisch then it will work
Alfa 156 1.9 JTD 105HP
Alfa 147 1.9 JTD 16V 140HP
Alfa 155 1.6 TS 120HP
