actual boost pressure too low in lower rpm, is this normal?
onnaj
Post by onnaj »
I've check my boost pressure cause something is not completely well with the car. When i would drive away in low rpm, sometimes the cars seems to shutt off, but mostly when i pressure the gas pedal (much too) deep it'll keep on moving but hestitates a bit. It does this sometimes but not always and i cannot find out what is casuing the problem. That's why i've made a run with actual vs desired boost pressure.
Only thing i see is that the desired boost pressure is much higher than the actual boost pressure in lower rpm. I've added the multiecuscan file with the boost pressure from 1000 rpm till 4500 rpm in 3th gear.
Can someone tell me if this is normal and/or the vaulues are good?
Thanks.
3e versnelling.csv
actual vs desired boost pressure (3th gear)
(2.41 KiB) Downloaded 659 times
EnIgMa
Re: actual boost pressure too low in lower rpm, is this norm
Post by EnIgMa »
maybe?
i really don't know...
is you car a turbo-charged car?
what exactly means desired boost pressure?
if you flatout you would a high-pressure but you can't have it because the turbo is not spooling at full speed.
onnaj
Post by onnaj »
Yes boost mean its either turbo- or supercharged, otherwise my car would suck :D
onnaj
Post by onnaj »
Yes boost means that either your car is turbo or supercharged. If my car would'nt boos it would suck :D :P
maxim
Post by maxim »
could be the EGR valve only if a dirty low revs the engine has no strength
sorry for my bad English
onnaj
Post by onnaj »
I've cleaned my EGR as turbo sensor as well past month. They were very dirty, but are now super clean. So the egr shouldn't cause the problem.
Any suggestions?
EnIgMa
Post by EnIgMa »
i don't get it, sorry.
But is it a recent issue?
do you have proof that your car is working different from past time? (sorry for my english).
onnaj
Post by onnaj »
No one that can tell me why the values could be so different between the boost levels?
coolbits
Post by coolbits »
Could be a lot of things...
Blocked EGR valve... split vacuum hoses or intake pipes, blocked vnt solenoid vave...
onnaj
Post by onnaj »
Can a bad boost pressure sensor also cause this?
